Bridges with ABS
What are the recommended settings for printing a bridge with ABS? I have extrusion ration down to about 75 I think. Im assuming fan is still not recommended even with bridges. Maybe increasing speed so it meets the other end before dropping?
Veröffentlicht : 19/06/2017 7:35 pm
Re: Bridges with ABS
With ABS it will be quite model dependent. Also depends on length of bridged section. Generally you should be OK with settings provided by PR. Fan is still not recommended, but sometimes it helps. 😉
Veröffentlicht : 19/06/2017 10:09 pm
