Big problem with Warping - PLA
Strona 2 / 2
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Big problem with Warping - PLA
Giannis
My Live Z Adjust is a mere 0.025mm. I would suggest that your probe is somewhat low, but I still think lowering the nozzle a very small amount would help you.
Peter
Opublikowany : 22/12/2016 6:59 pm
giannis.f
(@giannis-f)
0.025? wow thats huge difference! I will try to lower the nozzle a little more.
Thanks Peter!
Opublikowany : 22/12/2016 10:19 pm
PJR
 PJR
(@pjr)
Giannis
There is a good thread about probe height here: http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/pinda-probe-height-de-mystified--t2588.html#p20436
Peter
Opublikowany : 23/12/2016 8:43 am
jason.c2
(@jason-c2)
I have similar issues when I print (PLA) - even with small items. After some testing I realized that it had to do with the ambient temperature in the room. Winter just kicked into high gear here in Canada and I found that I have to turn up the heat when I print. My place is usually around 72 (F) (which is somewhat cold) I turn up the heat to 76 (F) and this helps a lot. I am thinking about building an enclosure.
Opublikowany : 28/12/2016 5:10 am
Strona 2 / 2
