Best settings with transparent(ish) PLAs such as Crystal Clear "Transparent"
[Geschlossen] Best settings with transparent(ish) PLAs such as Crystal Clear "Transparent"
valmotis
(@valmotis)
Hi peeps!
I have had issues with the transparent(ish) filaments that I haven't had with the plain PLA material (all Prusa filament but not prusament). I found that sometimes the filament stops being extruded but the printer keeps going and I would typically discover the problem in the morning looking at the printing head "printing" nothing in the air. It looks like a "soft clog" as when I remove the filament it will all come out if I pull firmly but slowly and I don't have to change the tube or unclog the printing head itself. So the problem looks like the filament is not in the printing head itself but above it. The filament looks a bit rough and would not go through the tube anymore. I know it could have happened if the spool got stuck and the filament doesn't come down anymore but it wasn't the case in the past couple occasions. Anyone knows what could be done to avoid these issues? At the moment I'm printing at 225 degrees (recommended temps are 210-230) as I found that lower than 225 tended to under extrude. I would be interested in knowing how others are handling these transparent or almost transparent PLAs which are to be heated between 210 and 230.
Thanks for your time 🙂
Tom
Veröffentlicht : 19/08/2019 10:05 am
valmotis
(@valmotis)
RE: Best settings with transparent(ish) PLAs such as Crystal Clear "Transparent"
Sorry about this. Posted in the wrong section... Can this be deleted? I think I can't delete it myself anymore.
Veröffentlicht : 19/08/2019 10:46 am
