[Closed] Best setting for gold Silk PLA
bmlb929
(@bmlb929)
Was given Mika3D silk PLA.  Gold, silver, and bronze.  I am having difficulty with globbing and bed adhesion.  Using an i3 mk3s. I am trying to print some letters but it does not stick to the bed.  Hardened steel nozzle The extruder is set for 220 and the bed is set for 60.   I am a beginner when it comes to 3D printing.  Regular PLA is easy for me.  Past that, I am swinging and missing.  Thanks in advance.
Napsal : 21/07/2019 2:40 am
RE: Best setting for gold Silk PLA
PLA bed adhesion comes down to two things: 1) bed contamination and 2) bed cleanliness.
Layer one thickness helps: as long as it is less than one nozzle diameter.
Try cleaning the bed (alcohol doesn't count as a cleaner unless you were wearing gloves and used at least 250 ml to rinse).
Napsal : 21/07/2019 3:58 am
bmlb929
(@bmlb929)
Got the bed problem fixed.  Now the extruder is clicking loudly and filament is not moving.  Missing layers on prints.  Need help.
Napsal : 22/07/2019 3:04 am
PJR
 PJR
(@pjr)
Antient Member Moderator
I printed this cat money box mainly with silk bronze PLA:
The only problem I had was with the additives, especially at the start of a print.  When the print was removed from the bed it left behind a film of PVA-like substance.  I presume this also coated the inside of the extruder.
I did a couple of cold-pulls and changed the nozzle and was then able to print the next part without issue.  I repeated the cold pulls after I had printed with the silk filament.
Peter
Napsal : 22/07/2019 7:44 am
bmlb929
(@bmlb929)
I appreciate the help.   But being a newbie I don't know what a cold pull is.   What is that?
Napsal : 22/07/2019 2:10 pm
PJR
 PJR
(@pjr)
https://forum.prusa3d.com/forum/?wpfs=cold+pull
Peter
Napsal : 22/07/2019 2:23 pm
