Bed glue for ABS (updated)
jmmprog
(@jmmprog-2)
Hi i trying different glue for the bed
my last found new mixture work good..is a Maizena (Corn starch ) see a picture
i using a mixte 2 by 1(exemple 50gr Maizena with 100ml water.
extruder to 255 degrees and bed to 100 degres
using directly in bed with 60 degrees temp,the adhesion is good and you can cleaning with worm water
TEST
honeycomb layer 0.20
clean with warm water
the result
and
Respondido : 24/04/2016 1:28 am
Nigel
(@nigel)
Re: Bed glue
Wow. Wonderful use of corn starch.......
Nigel
Respondido : 24/04/2016 5:27 am
richard.l
(@richard-l)
Miembro Moderator
Re: Bed glue for ABS (updated)
Makes me wonder if spray starch used for ironing would work.
Respondido : 25/04/2016 4:14 am
jmmprog
(@jmmprog-2)
richard,i dont know i not try but is possible if you try and i work tell me!!!!
Respondido : 25/04/2016 8:24 am
christophe.p
(@christophe-p)
Miembro Moderator
Nice ! Interesting indeed !
It seems a good way to unstick fragile prints from the glass, when it's challenging to do with ABS juice. when the stick is strong.
How do you apply it on the glass and how do you spread it so it can make a regular thin layer ?
Do you have to wash it before reapplying between each print ?
Thanks for the share !
(And I do not know why I have strongneed for a "blanquette de veau" now 😉 )
I'm like Jon Snow, I know nothing.
Respondido : 25/04/2016 11:29 am
jmmprog
(@jmmprog-2)
Hi christophe, i apply a mixture with a 1 inch brush and when the print is finish just use a warm water only and after the glass is dry i apply a mixture again..
Respondido : 26/04/2016 8:24 am
Jarred
(@jarred)
Cool idea, is this your "go-to" now? Or do you use this method solely for fragile prints?
Respondido : 30/04/2016 8:21 pm
Nigel
(@nigel)
Corn..... The same as PLA. Always use a raft with ABS and heat the bed to 100degC.
Nigel
Respondido : 02/05/2016 2:26 am
jmmprog
(@jmmprog-2)
Hi jarred.no i use for all part bigger and smaless 🙂
Respondido : 08/05/2016 9:19 am
jmmprog
(@jmmprog-2)
Nigel i try with abs with standard mode ,bed to 100 degrees
Respondido : 08/05/2016 9:21 am
