Bad result importing stl in Prusa3d Slie3r
olivier.l6
(@olivier-l6)
I'm still in learning mode on how to use my Prusa 3D printer ....
the easier way is to print from an existing stl file ...
I found on thingiverse a Milenium battleship ...
Then .. start PRUSA 3D slic3r ... add stl file
but my bad surprise is that I have a lot of manifold error and hole in the object.
Seems that there is no problem with CURA.
Then who can help me to understand how to have a good result. Perhaps some parameters ....
Thanks in advance.
Respondido : 12/09/2017 4:54 pm
Wirlybird
(@wirlybird)
Re: Bad result importing stl in Prusa3d Slie3r
Probably need to run the STL through a fixer such as makeprintable.com or netfabb.
Respondido : 12/09/2017 7:37 pm
AJS
 AJS
(@ajs)
Or MeshMixer or meshlab
Respondido : 16/09/2017 2:40 am
