Am I suppose to be able to access SD card from Windows explorer?
Janne
(@janne-2)
I can not se the SD card on Windows explorer so I can not transfer the g code files there for printing.
There must be a way to add and remove files?
Is it a setup problem with my computer or am I not suppose to be able to access SD card from Windows via the print cable?
Opublikowany : 31/01/2018 4:59 pm
ManelTo
(@manelto)
Re: Am I suppose to be able to access SD card from Windows explorer?
I suppose it's a problem with your setup, I see mine perfectly. If you have another SD, put a gcode file from you computer and put it in de printer to test it.
Sorry for my poor English. I try to do my best.
Opublikowany : 02/02/2018 2:19 pm
Janne
(@janne-2)
Thank you.
I thought that it should be possible read the SD card when it was in the printer, is that possible?
I spent I whole day trying to do that.
Anyway I start to believe that is not possible, so I have changed to a computer with built in SD slot so the problem is solved. 😀
Opublikowany : 03/02/2018 2:08 pm
digibluh
(@digibluh)
Thank you.
LOL.... yea, with a wifi SD Card....
Opublikowany : 08/02/2018 4:20 pm
Andy
 Andy
(@andy-12)
Make sure that you have not accidentally pushed the white slider to the locked position. Have you tried to format the SD card?
Original Prusa I3 MK2s with 2.5 upgrade; Original Prusa I3 MK3s; Slic3rPE; FreeCAD
Opublikowany : 11/02/2018 11:17 pm
