abs delamination
mathew.p
(@mathew-p)
abs delamination
How can i stop my ABS prints delaminating randomly between layers. I have read on reprap forums that the solution was to crank up the extrusion temp. I tried 265 up from the default 255 in slicer but the printer aborted the print with "err: max temp".
Cheers
Publié : 05/11/2015 6:29 am
renegadesk
(@renegadesk)
Re: abs delamination
Are you using default settings in slic3r from Prusa Research ? I never had that problem. Is your bed level ?
Publié : 05/11/2015 10:21 pm
mathew.p
(@mathew-p)
yes and yes
Publié : 06/11/2015 1:42 am
angus.g
(@angus-g)
sometimes you can't stop the delamination, one of the issues with abs. How high are you trying to print? As I understand it anything above an inch or two starts to run into issues.
Have you tried putting a shield around the printer to stop any drafts getting on the print? that has helped me in the past.
Angus
Publié : 06/11/2015 12:44 pm
mathew.p
(@mathew-p)
trying to print up to about 50mm, think your onto somthing with the drafts.
Will build a enclosure and see it if it improves things.
Cheers
Publié : 08/11/2015 9:15 am
Josef Průša
(@josef-prusa)
Membre Admin
Alway post a picture of the failed print, this way we can help the best 🙂
How big is the part?
Founder and owner / Majitel a zakladatel
Publié : 30/11/2015 7:53 pm
