0.15mm slic3r settings
Clive
(@clive)
I'm really liking the prusa slic3r settings, but there doesn't appear to be any 0.15mm print settings.
Is there a way to export the settings from the "buddy" test print that's on the sd card?
Postato : 22/10/2016 2:42 pm
David T.
(@david-t)
Re: 0.15mm slic3r settings
Load slic3r settings for 0.2mm, go to Print Settings -> Layers and perimeters and change Layer height to 0.15mm, First layer height to 0.15mm. It is not a rocket science.
Postato : 22/10/2016 2:56 pm
richard.l
(@richard-l)
Utenti Moderator
David
You are assuming all the other settings are the same. With a .15 layer height you would also need to increase the top layers to 4 or more and possibly increase the perimeters.
Postato : 22/10/2016 6:11 pm
David T.
(@david-t)
That setting worked for me without any other modifications. 0.15 is pretty close to 0.2
Postato : 22/10/2016 6:36 pm
