Z axis sticking
william.b25
(@william-b25)
Z axis sticking
just assembled my new i3 mk3 and it can't get through the calibration process. the Z axis' are grinding or sticking and get a Z axis error msg.
could i run a software update to fix?
Posted : 23/03/2018 11:29 pm
x50arm
(@x50arm)
Re: Z axis sticking
Check and make sure the plastic covers that screw down over the motors are not too tight and causing binding.
Posted : 24/03/2018 12:11 am
Nikolai
(@nikolai)
Re: Z axis sticking
If you hear a mechanical noise, most likely there is a mechanical issue. Try to find and solve it!
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Posted : 24/03/2018 12:16 am
RH_Dreambox
(@rh_dreambox)
Re: Z axis sticking
Check if the spool holder is on the right side. It should be mounted on the back of the frame, otherwise it will collide with the X device during the calibration.
Posted : 24/03/2018 4:13 pm
