X & Y Axis drift tolerances
The MK3 manual declares the belt tightness value and +/- offsets. After building my kit, both were in range. Now after many hours of glorious prints, I'm noticing that the X-value is starting to drift up past 280 (287). I'm wondering at what point should I attempt to re-tighten the belt?
Or is this more of an issue with the belt itself developing slack irregardless of measured value?
FWIW, I re-ran the Self Test to get the belt test measurements again. Please make sure that you run up the Z-axis up to the top so it levels out before starting this.
Postato : 28/03/2018 4:27 am
