WHY do these printers still not ship with hotend socks?
devilhunter
(@devilhunter)
As the popularity and the shipments of the Prusa i3 MK2 grew, it started popping up everywhere.
Reddit, Facebook feeds, Thingiverse. Just about everywhere you can recognize the MK2 right away from a photo that does not even show more than a few parts of the printer.
The "ORIGINAL PRUSA" on the heatbed, the "HOT!" on the nfan nozzle, the bright safety ABS orange parts.
And just about every 2 or 3 days i see these catastrophic fails on a MK2, aka Hotend blobs on Reddit, and on Facebook. Sometimes even on Twitter or Thingiverse Forums. Photo included is from Prusas own knowledge base.
These catastrophic failures can have only two reasons:
- Print lifted from the heated bed and got stuck on the big 200+ degrees heaterblock, new extruded filament will collect there as well as one massive molten blob.
- Nozzle or heatbreak not correctly tightened into the heaterblock when hot. Filament will leak out over time then, and will slowly drip almost as a liquid onto the bed, while still accumulating on the heaterblock.
More than 90% of these catastrophic failures can be attributed to the first error, the print lifting from the bed and sticking to the heaterblock.
People try to fix it almost always do it wrong, ripping off thermistor cables or damaging other components.
And almost all of these 90% could be avoided if Prusa would throw in just one or two E3D Silicone Socks. Prusa, you supply the genuine E3D hotend already, why not throw in a 1 dollar silicone sock?
I've been using the sock since my first 'almost' catastrophic failure a year ago, never had a problem with them since.
The silicone sock has these benefits:
- clean heaterblocks & no catastrophic blobs on the heaterblock forever
- the temperature of the hotend is MUCH more stable, even without PID tuning, as you can see in octoprint's temp graph
- the Printer will consume less energy because there is no filament fan that keeps blowing some of the cold air onto the heaterblock. the Heater cartridge has to work extra hard to keep the heaterblock hot; with the silicone sock no cold air gets to it, and the silicone even has a heat conserving ability for the heaterblock. you can actually measure this with a watt meter, the printer will consume about 4 - 5 watts less with the silicone sock on the heaterblock.
- provided you cool the 3D prints adequately and avoid upwards curling prints, the silicone sock will last months. Sharp curling prints will rip off small pieces of the silicone sock, or in some cases will rip off the sock from the hearblock entirely. (the sock survives this unharmed)
Mr. Prusa, why is this silicone sock still not included even with your newest and most 'smartest' of your Printers?
Raise the Price of the Printer for one dollar for all we care, this saves a lot of people big headaches with the issues mentioned above.
Veröffentlicht : 17/02/2018 11:18 pm
thrawn86
(@thrawn86)
Re: WHY do these printers still not ship with hotend socks?
In principle I agree, but I've had failures even with a sock. heater block cable gets tweaked and sock starts to droop, etc. It doesn't absolve us of properly cleaning the nozzle, either. I have a whole bag of of genuine socks and the fit is hit or miss.
No issues with temp stability here, but I can see the argument for keeping heat away from small details and shorter layers.
Veröffentlicht : 17/02/2018 11:37 pm
imod.systems
(@imod-systems)
Here's why I think horned socks could be a bad idea. Over time they will become loose and no longer sit on the tip of the nozzle properly. With the sock no longer securely fit against the block filament can extruded into the sock and cause a blob.
This actually happened to me so I speak from experience. The sock became loose, dragged onto a print, and filament started to extruded into the sock causing a blob. Thankfully I caught it in time and didn't become another blob victim.
Veröffentlicht : 18/02/2018 12:01 am
Iluvatar_Bzh
(@iluvatar_bzh)
I ask them with the chat before the shipping if they can put one sock with my printer. I receive 4 of them
Veröffentlicht : 18/02/2018 12:03 am
I too, had a blob that was trapped inside the blue sock, and directed straight into the cabling on the heatblock!
it looked like the original print, detatched from the printbed, and skated around, whilst the extruder continued to pump filliment out of the extruder, the silicone sock, seemed to act as a thermal barrier, causing the filament to flow inside the sock in preference to outside the sock...
Veröffentlicht : 18/02/2018 12:10 am
moojuiceuk
(@moojuiceuk)
Josef himself has said this about including a sock:
We’ve had to many socks fall out on the farm ruining the prints and hotends to include it ...
https://shop.prusa3d.com/forum/original-prusa-i3-mk3-f30/is-a-silicone-sock-on-the-heater-block-possible--t6276-s10.html
I love the socks Ive put on my K8400 and I have a sock ready and waiting for my MK3 when it arrives. In my opinion they work, but I don't have 300 printers working 24/7 😀
Veröffentlicht : 18/02/2018 12:14 am
Spekkie3D
(@spekkie3d)
Indeed i read or heard Joseph say they had troubles in the print farm using the socks.
That being said, i also have 2 original socks ready and waiting for my mk3. the 3rd of the pack of 3 is currently installed on my clone printer (as the one that i got with the Titan Aero on that machine was becoming loose).
I think that although they have had issues with them on the print farm, i would have liked it to be included. But just with a warning that you should always make sure the sock is not too loose, and if so you know it can be a rist.
Veröffentlicht : 18/02/2018 12:55 am
Bill
 Bill
(@bill-3)
I have about 10 socks on hand and have used them since I had a blob on my MK2 last year. I also had a near failure saved by the sock on at least one occasion and I mentioned it in the MK2 forum.
From what Joan and others have experienced with the sock catching and holding on to filament after slipping off, I wonder if the catastrophe would have still occurred without the sock anyway??? May be impossible to discern. I personally think the advantages outweigh the disadvantages. But, I agree with Josef not providing them and letting the individual user decide. The socks can be bought from multiple sources in multiple countries so the shipping costs are not really an issue and they are pretty cheap.
Veröffentlicht : 18/02/2018 3:31 am
MikiCab
(@mikicab)
I have said the same thing many times. Why wasn't I born with socks on? I put them on every morning and think why God didn't include socks? He's Bloody Omnipotent for Christ Sake.
Veröffentlicht : 18/02/2018 6:06 am
thrawn86
(@thrawn86)
Same here. easier to brush clean or pick away stringers during a print without it too.
Veröffentlicht : 18/02/2018 7:00 am
imod.systems
(@imod-systems)
The issue I had was the sock coming loose from the violent movement of the extruder while the printer printing infill at 200mm/s. It was enough to jostle the sock loose and it came in contact with a print and filament started to extrude into the sock. I was lucky enough to be watching my printer closely when it happened so I caught it right away.
Veröffentlicht : 18/02/2018 1:38 pm
JMcK
 JMcK
(@jmck)
For the in-sock blob victims; did you have the "pro" sock where just the tip of the nozzle sticks out?? https://e3d-online.com/v6-socks-pro-pack-of-3
Or was it the "new" design that leaves the whole cone of the nozzle exposed?? https://e3d-online.com/v6-sock-3pack
It seems like the new design would be less likely to shift enough to blob inside itself, but it also leaves more metal exposed, like the set screw. so trade-off. E3D says the new is better for 99% while the "uncut" sheath is for special use cases.
When someone asks you if you're a god, you say, "YES!"
Veröffentlicht : 18/02/2018 3:14 pm
rotarypower101
(@rotarypower101)
I think using fasteners into the block to hold the sock in place tightly would be the best solution for any issues with looseness or issues where the sock might come away from the block.
It seems like with very little effort and refining of the concept, it would bring a great benefit to many people that have these issues.
Veröffentlicht : 18/02/2018 6:49 pm
JMcK
 JMcK
(@jmck)
I was thinking a 1/8" or 1/4" strip of Kapton, all around the upper rim.
Veröffentlicht : 18/02/2018 8:25 pm
I had the pro version
Regards Joan
Veröffentlicht : 18/02/2018 9:08 pm
stoofer
(@stoofer)
I'm a sock lover. Pros outweigh the cons for me.
Veröffentlicht : 18/02/2018 10:31 pm
JuanCholo
(@juancholo)
just wanted to add i love the Sock as well. i have the full open version not the pro. the benefits outweigh the problems.
“One does not simply use a picture as signature on Prusa forums”
Veröffentlicht : 05/04/2018 7:27 pm
alan.e2
(@alan-e2)
Might be of interest, seeing as it has a garter screw to help hold up the sock: https://makerware.thingiverse.com/thing:2740613
Veröffentlicht : 05/04/2018 10:47 pm
Zcubed
(@zcubed)
This is exactly what I did with my pro sock. Used some 1/8" kapton tape I had to wrap completely around the top of the sock and tape over the heater cartridge holes for safety. I also wrapped the outgoing wires with some tape too. If anything the tape protects the wires even more from blob damage if it occurs. At the same time I have an Octopi installed on my einsy with a webcam for remote viewing and kill switch in case of any failed long prints.
https://www.thingiverse.com/zcubed/things
Veröffentlicht : 09/04/2018 8:16 pm
