Which variant do you use for the MK3 to compile the firmware on Github?
The Latest Firmware can be found here https://github.com/prusa3d/Prusa-Firmware/releases
Open Firmware Issues https://github.com/prusa3d/Prusa-Firmware/issues
Opublikowany : 09/03/2018 1:03 am
Re: Which variant do you use for the MK3 to compile the firmware on Github?
I think it's probably 1_75mm_MK2-RAMBo13a-E3Dv6full.h as that is the board included with the MK3, link to board reference here.
Opublikowany : 09/03/2018 2:02 am
Just clone MK3 repository, is all you need. The config file is already on place and no need to config or change.
Opublikowany : 09/03/2018 3:42 am
Yes do NOT copy any file in. It will not compile at all...
Opublikowany : 09/03/2018 9:44 am
