Where Does This Piece Go?
Allanimal
(@allanimal)
So during a print today, I ran out of filament.
When I tried to load new filament, the extruder pulled it in a bit, and then it just made clacking sounds and didn't extrude anything.
After several attempts to unload and load the filament, I opened the access port on the side of the extruder, and saw that there was still a length of the old filament inside, broken off below the gear. The unload function was not moving it at all, so I grabbed it with needle nose pliers and eventually managed to work it out, At the final pull, a small black piece also came with it.
I'm trying to figure out where this came from. Did it break off or just come loose some how?
I can't tell if there is a broken edge on it - it is smooth everywhere.
If it is broken, do I need to replace the piece, and which piece?
Here are some pictures of it, from various angles.
Anyone recognize it?
Opublikowany : 23/03/2018 8:39 pm
reid.b
(@reid-b)
Re: Where Does This Piece Go?
That is just a simple light blocker piece that goes on the top of your extruder idler cover.
Opublikowany : 23/03/2018 8:42 pm
nolan.l
(@nolan-l)
Here's the step in the guide. It covers filament sensor so light can't get in.
http://manual.prusa3d.com/Guide/5.+E-axis+assembly/510?lang=en#s8312
Opublikowany : 23/03/2018 8:45 pm
Allanimal
(@allanimal)
Great! Thanks!
I was really worried I broke something.
I guess thats the disadvantage to getting an assembled printer instead of the kit... You don't have a frame of reference for these bits.
Opublikowany : 23/03/2018 8:55 pm
Dewey79
(@dewey79)
Great! Thanks!
You can always access the online guide for building the printer and walk through each step and glance at the pieces.
Opublikowany : 23/03/2018 9:06 pm
Allanimal
(@allanimal)
Great! Thanks!
I actually tried to do that, but I was so convinced something broke off I was only looking at pictures bigger parts to figure out where this came off. I totally missed the relatively small, in comparison, section about this part.
But thanks, it is a good reminder to read thru the assembly instructions when trying to track down some issues.
Opublikowany : 24/03/2018 5:23 pm
I found that part incredibly fiddly, especially with long nails...
and there is no way that I am going cut them...
so last time I lost that piece, i made one that was easier to hold, and insert[attachment=0]20180324_170809[1].jpg[/attachment]
it looks like the object above
and was made by putting the first copy into slic3r, flipping it on the Y axis
then adding a second copy, then moving them together till the two tops touched...
now i have a plug that will go in either way round, it's easier to grip, and harder to lose...
WIN WIN WIN
Joan
Opublikowany : 24/03/2018 6:29 pm
