Varible layer heights usage
hairy jaws
(@hairy-jaws)
Hi
has anyone been using the variable layer height in the Prusa slic3r, i haven't seen much mention of it on the forum. if anyone has used it can you share the results good or bad. this seems like a great thing to get extra detail where you need it etc.
i have also read a couple of threads where people had bad top layers and i thought that variable layer height would have helped that kind of issue out.
Publié : 30/03/2018 9:14 pm
Kwaad2
(@kwaad2)
Re: Varible layer heights usage
I use it for overhangs. 0.15 I can get around 70 degrees with no relevant sagging. 0.05mm I can get around 80degrees.
It looks nice too. Much faster than a full print at 0.05... Which I do way too often. Lolol
Hi, I'm Sean. I used to work on CNC machines.
I try to not make mistakes, but the decision is YOURS.
Please feel free to donate to my filament/maintance fund.
Publié : 31/03/2018 5:18 am
hairy jaws
(@hairy-jaws)
thanks for sharing that sean.
Publié : 31/03/2018 4:10 pm
