Unable to run first time setup guide
troy.w4
(@troy-w4)
Hello all,
I just received my MK3 today. But I'm running into an issue that I cannot seem to figure out. The printer loads up to;
'Hi, I am your Original Prusa i3 printer. Would you like me to guide you the setup process?'
I select Yes and both fans spin up for a couple of seconds and then stop. When they stop, I get the Hi, I am your Original Prusa printer, prompt again.
If I select No, the same thing happens. It is stuck in a loop.
Any ideas what could be the cause?
Thanks in advance,
Troy
Napsal : 29/03/2018 12:34 am
Olef
 Olef
(@olef)
Re: Unable to run first time setup guide
Hi Troy
Are you pressing the selection knob itself to answer yes? Or are you pressing the tab with the X on? It should be the selector not the X tab.
Napsal : 29/03/2018 12:37 am
troy.w4
(@troy-w4)
Thanks Alfred. That was it.
Sorry for the newb mistake.
Napsal : 29/03/2018 12:43 am
Olef
 Olef
(@olef)
You're not the first to confuse this and won't be the last, it's no biggie. Enjoy your printer 🙂
Napsal : 29/03/2018 12:56 am
Kwaad2
(@kwaad2)
hahahaha, I never even thought of this!!! I'm glad I saw this. I won't forget it... for a while at least!!
Hi, I'm Sean. I used to work on CNC machines.
I try to not make mistakes, but the decision is YOURS.
Please feel free to donate to my filament/maintance fund.
Napsal : 29/03/2018 1:36 am
