[Closed] Suddenly printing out of sync!
rafaelvaldez5640
(@rafaelvaldez5640)
So I bought and assembled my prusa i3 mk3s about 3 weeks ago and it started printing fine, I´m fairly new at this but there were no gaps and the print was clean. Anyways. About two days ago when I updated the firmware to 3.8.1-2869 it started printing way to the right and now it just doesn´t follow the print at all, it prints on top of the outline and it won´t close the lines as you can see in the picture. So I did the Wizard calibration again a few times and it passes everything, I tried diferent fillaments and I also check the extruder and the Einsy box if any cables were not right but everything looks fine so I´m not really sure how to fix it. Any thoughts on what might be?
Any help will be greatly appreciated, and thanks in advance.
Rafael Valdez.
Napsal : 14/11/2019 7:01 am
Dave Avery
(@dave-avery)
RE: Suddenly printing out of sync!
check the set screws on the y axis pulley - i bet they are slipping
Napsal : 14/11/2019 6:38 pm
That and the plastic is not adhering to the bed; Live-Z is off by a lot.
Napsal : 14/11/2019 7:41 pm
