​​Stealth​​ mode layer shifting
sMart
(@smart)
I had issues will printing the Benchy in ​​Stealth ​​mode, layer shifting. At one point, the printer start shifting each layer for no reason (see picture). Someone have the same issue?
Opublikowany : 23/12/2017 7:57 pm
Frank
(@frank-14)
Re: ​​Stealth​​ mode layer shifting
7.2.4​ ​Normal​ ​vs.​ ​Stealth​ ​mode
The printer offers two print modes. Normal​ ​mode​ is required for the detection of lost steps
(shifted layers) while still being quieter that silent mode on MK2/S. The second is called
Stealth​ ​mode​ and utilizes Trinamic StealthChop technology making the printer almost
inaudible with print cooling fan being the noisiest part of the printer. Stealth mode however
doesn’t provide lost step detection
However even without detection it shouldnt go so badly wrong
Opublikowany : 23/12/2017 8:10 pm
reid.b
(@reid-b)
So no layer shift detection in stealth mode, but clearly the new drivers are either very susceptible to any kind of friction or are simply just too weak in stealth mode. Ughh...
Opublikowany : 23/12/2017 8:33 pm
Daniel Hellström
(@daniel-hellstrom)
you got the latest firmware? they limit the speed there to make layershifting less likely to happen in stealth mode.
Opublikowany : 23/12/2017 8:44 pm
sMart
(@smart)
Yes, the latest firmware.
Opublikowany : 24/12/2017 3:42 am
Paul Meyer
(@paul-meyer)
I just got a major layer shift (y direction) in stealth mode. Maybe 1cm into a part, then each layer had major shift. Haven’t had any issues in normal mode (including at least one 10 hr print).
Back to normal mode for now. Firmware was the one released last week.
Opublikowany : 24/12/2017 7:29 pm
