space between layers of Slic3r's 3D honeycomb
I'm printing a big piece that would hold a bit of weight so I decided to do the infill with 3D honeycomb instead of the default grid that comes with slic3r mk3's presets.
Appart from that I'm using the 0.2mm one and I think everything else is default if I remember correctly.
I have no experience with honeycomb 3D so maybe there is no issue here but it seems to be printing just horizontal or just vertical lines on the honeycomb so there is a layer height of gap between two consecutive vertical or horizontal lines. (see attachment)
Is that correct?
If it is wouldn't that affect piece strength?
Thanks!
Publié : 15/03/2018 2:54 pm
