[Zamknięte] Slicer software BUG
AndersÖ
(@anderso)
Slicer software BUG
This is definitely a software bug.'
Opublikowany : 17/01/2020 6:18 pm
AndersÖ
(@anderso)
RE: Slicer software BUG
This is very bad printing result.
This is definitely a software bug. Probably in the slicer.
Opublikowany : 17/01/2020 6:20 pm
vintagepc
(@vintagepc)
I don't entirely agree (yet). The lower part of the print's surface finish is very rough, suggesting you may need to review your printer assembly (unless this is what the STL looks like.) The Mk3(s) is capable of much better surface finish on smooth walls. Until that is rectified, it is hard to tell what is a slicing issue and what is a hardware issue.
Usual culprits to check:
Belt tensions
Grub screws, mounts on pulleys/idlers
Other printer screws
Filament feed
Print an included pre-sliced gcode. Does it have the same issues?
Opublikowany : 17/01/2020 6:54 pm
AndersÖ
(@anderso)
@vintagepc
This is an out-of-the-box pre-assembled printer. I specifically bought this to AVOID mounting/calibration issues.
Yes, the included models printed equally bad.
I'm 1000 euro disappointed.
Opublikowany : 17/01/2020 7:11 pm
Nikolai
(@nikolai)
@k-anders-ostlund
It looks like a vase to me. 😉 Please describe in detail what exactly do you think is wrong.
If you want us to check something, please add the project (3MF) file, so we can at least see the object, settings and material used.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Opublikowany : 17/01/2020 7:14 pm
AndersÖ
(@anderso)
@nikolai-r
The stripiness after the first cut-trough pattern is awful.
Adding "media" failed. How can I append a project file?
Opublikowany : 17/01/2020 7:31 pm
Compress the file into a zipfile. and attach the zipfile
Opublikowany : 17/01/2020 7:36 pm
AndersÖ
(@anderso)
@nikolai-r
Sorry. Here is the file (Fusion 360)
Opublikowany : 17/01/2020 7:37 pm
AndersÖ
(@anderso)
@nikolai-r
Here is the stl file.
Opublikowany : 17/01/2020 7:38 pm
AndersÖ
(@anderso)
Sorry one more time 🙂
Here is the ZIP file.
Opublikowany : 17/01/2020 7:42 pm
Try slowing down, particularly external perimeters. I use 25mm/s. It makes a big difference on consistency. You should also calibrate your filament and linear advance filament settings.
Opublikowany : 17/01/2020 7:45 pm
AndersÖ
(@anderso)
@bobstro
Thanks. Will try that.
Opublikowany : 17/01/2020 8:25 pm
rmm200
(@rmm200)
Even a pre-assembled 3D Printer is not a toaster oven. You can't just fire it up and print.
It takes a willingness to learn, attention to detail, and regular (daily if not more often) maintenance.
That includes cleaning the build plate.
Your printer can do great work - but it all comes back to the effort you are willing to put into it.
Opublikowany : 17/01/2020 9:32 pm
