Severe Jam
douglas.d2
(@douglas-d2)
Severe Jam
Hi all,
Ran some NinjaFlex through this thing this morning and had a decent print until the filament snapped and jammed. I thought I got it cleaned out, loaded some PLA back into the machine for a different print and lo and behold, all of the flex filament was not fully evacuated from the hot end. This resulted in the loaded PLA and the Flex being in the tube at the same time as you can see from the picture below. Followed the instructions to get the thing disassembled to this point but I am not sure what to do now. These filaments are tight in the tube and do not move. How can I get them out?
Any suggestions?
Thanks in advance
Edit: Got the PTFE tube out and removed the two jammed filaments. Got it back together now hopefully it still prints!
Posted : 17/03/2018 7:44 pm
Sean
 Sean
(@sean-6)
Re: Severe Jam
I would heat the nozzle and remove it then pull the ptfe tube out and extract the filament. more than likely that is not coming out without heating up the nozzle and heat block.
Posted : 18/03/2018 1:04 am
