Re: Selftest - X Axis Length
My printer had been working great and then I had issues with the prints not sticking to the bed and some layer shift issues. So I decided to go through the setup wizard again and got the X Axis Length error.
When my extruder head goes all the way to the left is where it seems to fail. If I manually move it that way it sort of moves all the way to the left and then when I let it go it rebounds to the right. From what looks like it's a belt issue with the gear. Has anyone else encountered and resolved this?
RE: Selftest - X Axis Length
In Step 35 "Mounting the X-carriage-back"(5. E-axis assembly) I apparently tightend the 2 screw on the top to much, as soon as I losend them the Selftest - X Axis Length worked.
I love you ian! You solved my issue too!
For Mk3S is the chapter 5 E-axis assembly - Step 61 X-Carriage-back assembly.
In addition, I think I also understand why. The armor tightened too much the 2 rods.
So the carriage was unable to go back well from its run.
Thank You
@tobias-b
Thank you! This solved my problem. Now it went trough the selftest without getting error about the x-axis lenght.
There is always hope!
