Selftest Error
phillip.m5
(@phillip-m5)
Selftest Error
Printer was working fine for 5-6 prints after receiving it but now I get "Please check : Heater/thermistor not connected" message. I've checked all visible connections and still get the same error. I've tried factory reset, firmware reinstall, moving the cables around (possible short or loose connection) and nothing seems to work.
Publié : 24/03/2018 5:14 am
stahlfabrik
(@stahlfabrik)
Re: Selftest Error
Do you get a sane temperature reading in support/ temperature?
Publié : 24/03/2018 12:33 pm
phillip.m5
(@phillip-m5)
Re: Selftest Error
In Support->Temperatures, they all fluctuate/change except "Nozzle = 0"
Temperatures as shown
Nozzle: 0C
Bed : 20C-22C
Ambient: 26C-27C
PINDA: 20C-21C
On the Main screen I'm now getting an "Err: MinTemp" message
Publié : 24/03/2018 4:38 pm
JMcK
 JMcK
(@jmck)
Re: Selftest Error
Best case, the connector to the Einsey vibrated loose. Unplug the printer open the door, make sure all the connectors are snug.
Worst case, there's a broken wire somewhere, and you need to replace the thermistor out to the print head.
When someone asks you if you're a god, you say, "YES!"
Publié : 24/03/2018 4:59 pm
phillip.m5
(@phillip-m5)
Re: Selftest Error
Connector is snug...
How do I go about purchasing a replacement thermistor?
Thanks
Publié : 24/03/2018 5:33 pm
RH_Dreambox
(@rh_dreambox)
Re: Selftest Error
Prusa Shop is always a good place to start looking.
https://shop.prusa3d.com/en/mk3-printer-parts/205-mk3-hotend-thermistor.html
Publié : 25/03/2018 2:16 pm
