Screen turns on then off
Mike
 Mike
(@mike-67)
I just unboxed and setup my preassembled mk3. When I power it on the screen turns on long enough for me to barely read "Original Prusa ..." and then shuts off. No noise. No response from buttons. Nothing. 😯
Any ideas?
Thanks.
Respondido : 14/01/2018 8:04 pm
moojuiceuk
(@moojuiceuk)
Re: Screen turns on then off
As nobody else has chipped in...
Firstly, whilst I've not yet received my MK3 - I have built a K8400 Vertex. My logical fault finding routine would go something like this...
If you have a multimeter and some confidence in using it... I would check out...
• Are you getting 24V DC to the Einsy board?
• Are the cables the right way around for the LCD display?
http://manual.prusa3d.com/Guide/6.+LCD+assembly/511?lang=en#s8279
and
http://manual.prusa3d.com/Guide/8.+Electronics+assembly/513?lang=en#s8274
• Have you got the daughterboard on your EINSY for the LCD and if so, is it connected to the EINSY ok?
• Has the LCD cable been snagged or caught on anything to damage it?
If you've checked out all that and still no joy, I would ask PR. Apparently they're quite good on live chat.
Respondido : 15/01/2018 10:06 pm
stahlfabrik
(@stahlfabrik)
Any ideas?
Thanks.
Is it dead since or does this happen every time you power it up?
Respondido : 15/01/2018 10:40 pm
george.f3
(@george-f3)
If the backlight is on, but you can’t see anything, the problem may be contrast setting. The back of the lcd controller has a tiny dial to change contrast.
https://goo.gl/images/G4dB3d
Respondido : 16/01/2018 2:05 am
Mike
 Mike
(@mike-67)
Oh my. Please tell me that's not the problem ....
Respondido : 16/01/2018 3:42 am
Mike
 Mike
(@mike-67)
Dang ... I see that the contrast dial isn't on their assembly guide either. http://manual.prusa3d.com/Guide/6.+LCD+assembly/511?lang=en#s8279&_ga=2.259820618.118664884.1515953385-1380025697.1515953385
I'll check the power supply next. Thanks guys ....
Respondido : 16/01/2018 3:48 am
PeterIkier
(@peterikier)
Isn't there a variable resistor? Seems to me that for R1 there are two places to fit in, a large one ("real" potentioneter) and a small one ("trimmer").
In your picture there seems the small one to be equipped - it is labelled "R1", just as the free space. So either one should work.
HTH
pi
Respondido : 16/01/2018 4:17 pm
