Replacement thermistor
Hey all,
I broke the thermistor whilst removing a failed print which had completely engulfed the hot-end...
If anyone can suggest which one to get to replace it, and thoughts on solder-repairing it (about 1.5" from the hot-end...)
Also, if there's any tips on getting the old one out/new one in that I should know about, I'm all ears 🙂
Pictures attached to show the kind of morning I've had ...
Re: Replacement thermistor
Thermistor cartridge from E3D. Will need cutting off the connector and/or some soldering.
The thermistor cartridge is held in place by a tiny grub screw in the heat block
