Raspberry Pi & Camera Mount
jakub.g
(@jakub-g)
Raspberry Pi case (becouse of MMU I will probably move it later to left aluminium extrusion of Y axis): https://www.thingiverse.com/thing:2334119
Camera - case & holder: https://www.thingiverse.com/thing:2736439
Raspberry Pi Zero:
Spacer: https://github.com/prusa3d/Original-Prusa-i3/blob/MK3/Printed-Parts/stl/rpi-zero-frame.stl
Einsy case with Raspberry access: https://www.thingiverse.com/thing:2734810
Veröffentlicht : 30/12/2017 2:31 pm
Protoncek
(@protoncek)
Re: Raspberry Pi & Camera Mount
Is it wise to mount camera to bed? Bed can move pretty fast in some cases, i think that cable won't last long... Isn't it better to fix it somewhere where it won't move?
Veröffentlicht : 30/12/2017 4:56 pm
jakub.g
(@jakub-g)
I used similar mount on MK2 for more than year without any problems. It is actually common practice. Due to fixed distance between printed object and camera, video is much clearer, and you can even make time lapses.
With object moving fast with heatbed and camera mounted somewhere else you can barely see anything at all. Also 1 meter length cable is less than 2 USD - in case it actually fail one day.
Veröffentlicht : 30/12/2017 10:27 pm
