PSA -- Heatbed cover loosening over time
Today I heard a noise from my mk3, which is unusual since it is normally very quiet. I looked over and happened to notice the cover for the heatbed connector was loose and brushing the gantry. When I stopped the printer and looked, the screw was in the left rear extrusion. apparently with vibration it had come completely loose. I checked with support and this is a maintenance issue and so if the wires ended up broken it would be a user issue not a warranty issue so make sure to check that screw and tighten it as needed. It should be sticking up a couple of mm from the top of the nut from what i see now that it is back to tightened.
Postato : 05/01/2018 5:58 pm
