Prusa MK3 3.2.0 beta Firmware
MarFoo
(@marfoo)
Hello,
how can i update my current MK3 firmware to beta firmware? I got the .hex file from GitHub. Can i use the hex file called "1_75mm_MK3-EINSy10a-E3Dv6full.hex" and flash it over Firmware Updater on my Printer?
best regards
Mario
Postato : 16/03/2018 11:24 am
ben.t7
(@ben-t7)
Re: Prusa MK3 3.2.0 beta Firmware
To update the firmware on the printer you need to hook it up to the computer by usb. Once you got the hex file downloaded to your computer you want to use the firmwareupdater tool that's in the drivers page that you download sli3r and system drivers. From there you just chose the hex file in the updater program and hit upload. Should take about a minute or so to update the file and you should be good to go.
Postato : 16/03/2018 11:55 am
stahlfabrik
(@stahlfabrik)
Hello,
best regards
Mario
I would say that is not the right file. When was it last changed?
I would suggest to only install released firmware if you are not 100% sure:
https://github.com/prusa3d/Prusa-Firmware/releases
Postato : 16/03/2018 12:59 pm
Olef
 Olef
(@olef)
3.2.0 is not beta, it is alpha. Respectfully I would advise you keep well clear of it until you fully understand what you are doing.
Postato : 17/03/2018 11:17 am
