problems with octoprint/prusaprint and camera on zeroW
klkl
 klkl
(@klkl)
Hello all together
Ive installed a raspberry zero w and it works very nice with octoprint and prusaprint (both 1.36, i cant see differences..) as long as I dont attach the camera.
When a raspi-camera is installed the system gets very unstable. even with 1 FPS and 640/480 the system hangs within minutes or at least in the first hour. It is not necessary to view the stream with a connected webbrowser. Ive tried several cameras (original 5MP, noname) with several resolutions.... similar results.
Has anyone a zeroW and the rasbicam running successfully?
Once i had got a crash while been connected with ssh running top. Does this gives someone more informations?
pi@octopi:~ $ top
top - 08:43:38 up 38 min, 1 user, load average: 0.24, 0.16, 0.15
Tasks: 92 total, 1 running, 91 sleeping, 0 stopped, 0 zombie
%Cpu(s): 2.7 us, 1.7 sy, 0.0 ni, 95.6 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
KiB Mem: 379576 total, 156384 used, 223192 free, 15856 buffers
KiB Swap: 102396 total, 0 used, 102396 free. 65412 cached Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
476 pi 20 0 79792 2268 1736 S 2.6 0.6 1:05.76 mjpg_stream+
429 pi 20 0 180184 43356 8044 S 2.0 11.4 1:41.13 octoprint
1001 pi 20 0 5104 2540 2160 R 1.6 0.7 0:18.45 top
966 root 20 0 0 0 0 S 0.3 0.0 0:02.71 kworker/u2:0
976 pi 20 0 11544 3472 2820 S 0.3 0.9 0:03.39 sshd
1 root 20 0 5372 3820 2736 S 0.0 1.0 0:04.04 systemd
2 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kthreadd
3 root 20 0 0 0 0 S 0.0 0.0 0:01.20 ksoftirqd/0
5 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/0:0H
7 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 lru-add-dra+
8 root 20 0 0 0 0 S 0.0 0.0 0:00.01 kdevtmpfs
9 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 netns
10 root 20 0 0 0 0 S 0.0 0.0 0:00.00 khungtaskd
11 root 20 0 0 0 0 S 0.0 0.0 0:00.00 oom_reaper
12 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 writeback
13 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kcompactd0
14 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 crypto
15 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 bioset
16 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kblockd
17 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 watchdogd
19 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 rpciod
20 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 xprtiod
21 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kswapd0
22 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 nfsiod
32 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kthrotld
33 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 bioset
34 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 bioset
35 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 bioset
36 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 bioset
37 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 bioset
38 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 bioset
39 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 bioset
40 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 bioset
41 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 bioset
42 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 bioset
43 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 bioset
44 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 bioset
45 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 bioset
46 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 bioset
Message from syslogd@octopi at Mar 18 08:43:39 ...
kernel:[ 2289.331462] Internal error: Oops: 17 [#1] ARM
kernel:[ 2289.360682] Process swapper (pid: 0, stack limit = 0xc08a4188)
kernel:[ 2289.362619] Stack: (0xc08a5ec8 to 0xc08a6000)
kernel:[ 2289.364491] 5ec0: c08a5efc c08a5ed8 c005e164 c005dbf0 c08a5f18 c08a5f18
I think ive tried everything. Does anyone has a idea what is going wrong?
Many thanks in advance.
Greetings Klaus
Publié : 21/03/2018 7:45 pm
Dr. H
(@dr-h)
Re: problems with octoprint/prusaprint and camera on zeroW
You may want to search the forum. I thought it was decided that the 0 simply did not have the power to do all that...
Publié : 21/03/2018 7:48 pm
