problem with the Extruder motor
Dan mor 2
(@dan-mor-2)
[code[/code]
it is clicking and no filament move in to E3D hotend
HELPPPPP
Dan
Posted : 19/03/2018 6:41 pm
reid.b
(@reid-b)
Re: problem with the Extruder motor
So little information.
Has it worked before this? If so, what led to this problem? Having little to go on, my guess is your extruder is clogged.
Posted : 19/03/2018 7:02 pm
Another possibility is a broken wire. Heat the extruder. Whilst waiting. Undo the two filament pressure screws. Open the trap door. And pull the filament out.
Then set the extruder to load filament and watch to see if the hobbed wheel on the motor shaft. rotates. If not its probably a broken wire...
Regards Joan
Posted : 19/03/2018 7:35 pm
Dan mor 2
(@dan-mor-2)
att is the video
I did 2 print before only
it is a new printer
Posted : 19/03/2018 7:58 pm
reid.b
(@reid-b)
Did it do this at all on the first layer? If so, was it because you run the first layer very slow?
What filament is this? It could be you are not running a high enough nozzle temperature- that would result in difficulty in extruding and a hot extruder motor.
Also- what size is your nozzle, and what layer height are you running?
Posted : 19/03/2018 11:45 pm
Dan mor 2
(@dan-mor-2)
Did it do this at all on the first layer? not all the time If so, was it because you run the first layer very slow?no it is running normally all the way
What filament is this?it is for all the filament including the original that I received in the box It could be you are not running a high enough nozzle temperature- that would result in difficulty in extruding and a hot extruder motor.i will try to up the temp today and see
Also- what size is your nozzle,04 and what layer height are you running?i try all the layer the extruder motor is still ticking
Posted : 20/03/2018 3:51 pm
jweaver
(@jweaver)
I don't think this will help, but could this be the pulley slipping on the motor shaft? Perhaps the grub screw is out far enough just to catch the flat on the motor shaft, but when its under load, it slips.....
Posted : 20/03/2018 4:00 pm
Dan mor 2
(@dan-mor-2)
no, it is not the pulley slipping on the motor shaft I checked it
it is running very good at the beginning of every print I did
bat after the 1 mm of printing it start clicking
Posted : 20/03/2018 4:12 pm
Dan mor 2
(@dan-mor-2)
ok
I increase the nozzle temperature to 220c and the printer starts to print well in 0.15 layer height
on 0.1 layer height and nozzle temperature 220c the printer is printing not so well and the extruder motor click from time to time
on layer height 0.05 and nozzle temperature 220c the extruder motor start clicking nonstop
ok it looks like it is missing significant from the correct parameter for every layer height
J.Prusa need to do a video of all parameters for every layer height to get the maximum form the printer and avoiding printer damaging
if anybody has a good experience for parameter per layer height I will be thankful.
temperature? speed? and the rest
thanks
Dan
Posted : 22/03/2018 3:07 pm
RH_Dreambox
(@rh_dreambox)
Prusa Slic3r has ready configurations for different types of filaments and different layer heights.
In the menu, choose the profile you want and you will get the correct configuration.
Posted : 22/03/2018 3:37 pm
