Prints stalling randomly
Seite 2 / 2
PixelPerfectCT
(@pixelperfectct)
Re: Prints stalling randomly
USB cable isn't the issue, tried several with the same results. Printer prints fine from SD card with no issues.
Veröffentlicht : 01/01/2018 5:05 pm
ormandj
(@ormandj)
This happens with me when using pronterface. Never have this issue if USB isn't connected. Get the same message about waiting for user mentioned previously.
Veröffentlicht : 02/01/2018 3:51 am
Chris
(@chris-16)
me too. i'm done with octoprint until i hear it has become reliable.
Recv: echo:busy: processing
Veröffentlicht : 03/01/2018 1:15 am
halfpress
(@halfpress)
Just experienced this on my hours old Mk3 printing one of the SD demo objects. Yes, OctoPrint was connected but just monitoring.
I'm not using the 143e firmware yet - just the current Dec 30 firmware (wanted to get a baseline first before I went into a more unique beta).
When people say it fails with "USB connected", does that mean literally physically connected whatsoever, or with a serial session active to OctoPrint or similar? I'm trying the same print again now with the USB connected, but I told OctoPrint to disconnect its session so monitoring isn't active. Granted, if this is random in some way, I don't know if I'm proving anything even if it it succeeds...
Veröffentlicht : 14/01/2018 12:18 am
gibsonlpsl
(@gibsonlpsl)
In my case, I meant it failed while printing from SD while octoprint had an active serial session. I closed that session but left the physical USB plugged in after I suspected the serial communication was a problem. I'm assuming others meant the same, but it wouldn't hurt to unplug the physical usb if you want to be completely sure.
Veröffentlicht : 14/01/2018 1:35 am
halfpress
(@halfpress)
Veröffentlicht : 14/01/2018 4:41 am
josh.w3
(@josh-w3)
I have also experienced half a dozen stalls while printing from SD, however my RPi0 was connected to the accessory port that whole time, and OctoPrint was monitoring. Given how problematic OctoPrint is at the moment I decided to disconnect it completely from the EINSY about a week ago. I haven't had a single issue since disconnecting, zero stalls or other weirdness. Until I experience any evidence to the contrary, I'm assuming that merely having the OctoPi physically connected (and/or having a serial connection open) was causing these SD printing issues.
I am really looking forward to a firmware update making the MK3 truly "OctoPrint ready" (as it was advertised back in September). Swapping the SD card 5-10 times daily is really getting old. I'd even settle for "USB ready" at this point.
Veröffentlicht : 14/01/2018 8:36 pm
Seite 2 / 2
