        Printer stops and make sound "bip bip bip"
My printer sometimes stops, the nozzle goes in the bottom right corner and there is a bip bip bip noise. On the screen, it is written "Press the knob and unload the filament". So That is what I do, then it tells me to put the filament again. and the printing goes on. But it keeps happenning anyway 10 or 20 minutes later.
What should I do ? I don't want to keep staying in front of it the hole time.
Thanks,
Yannis
                            Opublikowany : 15/03/2018 12:39 pm
                    Re: Printer stops and make sound "bip bip bip"
Disable your Filament Sensor.
It could be a problem with the Filament you use.
Try the "search" Funktion in the forum.
Everything is already well discussed.
nec aspera terrent
                            Opublikowany : 15/03/2018 1:01 pm
Here´s one example.
nec aspera terrent
                            Opublikowany : 15/03/2018 1:05 pm
