Printer external dimensions
Tenumen
(@tenumen)
Hi
I'm looking to buy the i3 MK3 printer but I'm a little space constrained so I'll need to keep the printer in my living space. So in order to print ABS I want to fit it into a ventilated enclosure.
Please can someone let me know the external dimensions so I can make sure I have room? Roughly, what's the overall size of the printer inc & exc the reel holder on top? Also what's the size of the four spool reel holder used in the multi material upgrade?
Thanks
Martin
Publié : 04/12/2017 2:30 pm
Mike
 Mike
(@mike-8)
Re: Printer external dimensions
If I remember correct, "Printer dimensions : 42 x 42 x 38 cm 6.5 kg (same as mk2s) but you should place it in to an empty space of W:45 D:55 H:60 cm" said live chat support guy.
Publié : 04/12/2017 3:43 pm
robert.b46
(@robert-b46)
I was told by someone on live chat at Prusa a few days ago that the dimensions are 45cm x 45cm x 50cm.
I read (somewhere on this forum) that you want to leave enough room so the cable bundle that moves with the print head doesn't touch the enclosure otherwise cable fatigue will happen sooner.
I'm waiting till mine is built and running before I build the enclosure.
Publié : 24/12/2017 5:24 pm
