Print stopping and random movement with Octopi
slayer1551
(@slayer1551)
Running the latest 3.1.1-RC4 b143 and twice now my print has randomly stopped and started extruding in one spot. Second time was after layer 6 in random spots. It also randomly travels to the front of the print bed and then moves back starts printing again.
Luckily I was watching and stopped it in time
Napsal : 30/12/2017 10:33 pm
ccfoo242
(@ccfoo242)
Re: Print stopping and random movement with Octopi
I think everyone is having this problem. There's another octopi thread with lots of stories. Something about the serial communication getting garbled.
Napsal : 30/12/2017 10:36 pm
slayer1551
(@slayer1551)
Just looked at my log and these are the last few lines before I rebooted the printed. I was using Octopi on RC3 fine and printed an 8 hour file. Will revert back and see if I can print the same gcode
| Send: N14926 G1 X110.795 Y73.412 E0.82358*86
| Recv: Error:No Checksum with line number, Last Line: 14925
| Recv: Resend: 14926
2017-12-30 21:26:36,807 - octoprint.util.comm - INFO - Got a resend request from the printer: requested line = 14929, current line = 14930
| Last lines in terminal:
| Recv: ok
| Send: N14923 G1 X112.123 Y97.368 E0.02819*92
| Recv: ok
| Send: N14924 G1 X111.314 Y97.567 E0.02818*86
| Recv: ok
| Send: N14925 G1 X110.795 Y97.744 E0.01856*81
| Recv: ok
| Recv: Resend: 14926
| Recv: ok
| Recv: ok
| Send: N14927 G1 X110.981 Y73.367 E0.00649*86
| Recv: ok
| Send: N14928 G1 X111.074 Y73.546 E0.00683*88
| Recv: ok
| Send: N14929 G1 X111.363 Y73.981 E0.01768*94
| Recv: Error:checksum mismatch, Last Line: 14928
| Recv: Resend: 14929
2017-12-30 21:26:39,586 - octoprint.util.comm - INFO - Got a resend request from the printer: requested line = 15037, current line = 15038
| Recv: ok
| Send: N15029 G1 X123.278 Y103.467 E0.10883*101
| Recv: ok
| Send: N15030 G1 X127.603 Y99.142 E0.20703*85
| Recv: ok
| Send: N15031 G1 X127.829 Y99.045 E0.00832*91
| Recv: ok
| Send: N15032 G1 X128.526 Y98.649 E0.02714*87
| Recv: ok
| Send: N15033 G1 X129.002 Y98.306 E0.01983*89
| Recv: ok
| Send: N15034 G1 X129.597 Y97.771 E0.02711*90
| Recv: ok
| Send: N15035 G1 X129.979 Y97.347 E0.01931*89
| Recv: ok
| Send: N15036 G1 X130.312 Y96.904 E0.01878*85
| Recv: ok
| Send: N15037 G1 X130.442 Y96.696 E0.00829*87
| Recv: Error:Line Number is not Last Line Number+1, Last Line: 15036
| Recv: Resend: 15037
Napsal : 30/12/2017 10:49 pm
Martin Stoufer
(@martin-stoufer)
Interesting to see things so out of order in the log. Looks like line 15037 got corrupted when received and there was a retransmit request that didn't make it. Can you capture this random movement again and see if its the same line and if it gets multiple retransmit requests? Perhaps there is a hole in the logic somewhere that silently gives up on the printing when the resend of a message does not occur.
Napsal : 31/12/2017 1:03 am
slayer1551
(@slayer1551)
It seems to be random. I just printed the same gcode from the SD card fine however another member has had it stall from SD so be careful guys! I wouldn't leave the printer unattended on RC4.
Originally I thought slic3r messed up but after spending ages looking through the gcode I decided to try again. The first time I saw random movement on layer 2 then it printed fine for 5 minutes then stalled at the front right and started oozing a big blob. The second time I saw random movement on layer 3 and then it stalled a few layers later in the middle of the print which is the photo in the post above. That's when I decided to trace back the log to see what was going on.
Napsal : 31/12/2017 1:21 am
