Print overlap and shifting
mike.r7
(@mike-r7)
Just put together my i3 MK3 and am having problems with the SD card loaded test prints. Pictures attached. There is come shifting and perimeter overlap that I can't figure out. I checked belt tensions and set screws for pulleys/idlers and everything seems ok. I haven't tried changing any slic3r settings to run new gcodes because with all the different possibilities I have no idea where to start. If someone could give my some ideas to look at it would be most appreciated. Thank you.
Respondido : 23/02/2018 2:23 am
RH_Dreambox
(@rh_dreambox)
Re: Print overlap and shifting
I think you have tightened the bed's bearings too tight (U-bolts) or the belt end pulleys do not rotate free. Loosen the belt and check that the pulleys and bearings slide without resistance.
Then make a first layer calibration again.
Respondido : 23/02/2018 10:07 am
mike.r7
(@mike-r7)
I checked the ubolts but they were not the problem. Turns out the x-axis pulley was very loose. Tightened up then tried printing again. Perfect! Thank you!
Respondido : 24/02/2018 3:57 pm
