Power Panic via OctoPrint
Simon
(@simon-16)
Hello to all,
I'm still mounting my fresh new MK3, so I could not test all the new features.
BTW, about the Power Panic, it's true it works only when printed via SD?
Or there is a way OctoPrint could resume it for you? I'm using OctoPrint on my old MK2S because I find it's nicer and you have control from remote.
Thanks,
Simon
Napsal : 29/01/2018 1:47 pm
thrawn86
(@thrawn86)
Re: Power Panic via OctoPrint
If the power really did go out your RPi would get restarted as well. so, yeah.
Napsal : 29/01/2018 4:09 pm
allabout3dblog
(@allabout3dblog)
The printer stores the line number where gcode needs to be resumed after power loss i guess.
Is it possible to query all those stored information via G-code or M-code?
This would allow to implement "Power Panic" plugin for Octoprint.
But it's clear that "print from SD" feature needs to be used from Octoprint ... no doubt.
If G-code and M-code for this are not available i would like to hereby request this feature. 😉
Napsal : 12/06/2018 8:48 pm
