Possible RC4 Bug
I'm not sure if this is the correct place to post but I am not as familiar with Github to post an issue there.
I just updated my firmware and ran the first layer calibration and got a value of about -0.9mm. After printing an object I remembered that I should "calibrate z". I ran this and then went to print another object. When I went to set my live adjust z I noticed that it had "remembered" my previous value but was not adjusting accordingly. I ended up resetting live adjust z and it came out to exactly double my previous value at -1.8mm.
Long story short, the calibrate z seemed to have reset the actual value in the firmware, but did not reset the number if that makes any sense. I can try to explain more if anyone has any questions.
Respondido : 31/12/2017 1:45 am
