Possible bug report - FW 3.1.3.245
Hello,
When printing the first object after powering up in Silent Mode my prusa calibrates itself and then move to the front left corner of the printing bed and hits the boundaries of x and y axis : which does not happen when in normal mode.
When printing second and next objects after powering up or when Normal Mode is selected the problem does not occur.
It is not the fault of slicer because i use the same gcode ( delivered on sd card with printer ).
Napsal : 05/04/2018 10:37 pm
Re: Possible bug report - FW 3.1.3.245
You should create an "issue" in Prusa's GitHub. IMHO here no one will read it.
Napsal : 06/04/2018 12:46 pm
