Re: Odd layer lines:
It sounds like you've ruled out software as a root cause. That leaves something electronic or mechanical.
It looks like there's no lines near the bottom, then they're really bad, and taper off after a while. Are the defects always at the same height?
If you search the MK3 forum for "layer lines" you'll see several things that affect the print. Your post reminded me of something so I looked back and provide it as a thought to you below.
... and other lighter color PLAs like to be printed at up to 230 degrees. layer lines will disappear a bit.
As I can provide time I want to put together a document on all MK3, 3D printing, filament issue and other troubleshooting issues in one document.
So,
I thought I’d try out using the Prusa Control application to export the gcode.
I can definitely say that the print quality is MUCH BETTER. This is leading me to think it’s the Slicr settings.
Now, I downloaded and installed the Slicr software using the Prusa bundle on here so it should have the right settings no?
