Octoprint and MK3 - some infos
Simon
(@simon-16)
Hello to all,
I'm using Octoprint to print with MK3 via USB port.
Until here I'm happy. It's great to monitor via webcam and user their plugins. I'll try the PiZero on the board in the future. For now I'm testing it via USB port.
But as far I know there are features that will be not available. I know I could try them by myself, but maybe someone has some informations and experiences.
  • Blackut feature: well, if Octoprint has no power, it cannot send the commands to the Prusa, so that will never work, right? Or are there workaround i.e. Octoprint can store it's position and resume on startup...
  • Filament change: Based on It's possible to change the filament. But when the print starts from Octoprint via serial??
  • Filament sensor: This is something I've tested. Via serial MK3 is not able to comunicate to Octoprint if the filament ends. Or are there workaround?
  • So, any other limit printing via Octoprint?
    Is there any way to use the MK3 features via Octoprint?
    Thanks a lot to all!!
    Simon
    Opublikowany : 05/02/2018 10:38 pm
    Simon
    (@simon-16)
    Re: Octoprint and MK3 - some infos
    Hello,
    Using the PiZero directly on the Prusa board would bypass those limitations?
    BTW if someone have experiences about what asked above (OctoPrint via USB), I would be happy if they could be shared. 🙂
    Thanks,
    Simon
    Opublikowany : 06/02/2018 4:41 pm
    Simon
    (@simon-16)
    Hello,
    Thanks,
    Simon
    Hello,
    Is someone that could give me those informations?
    I would like to install RPiZero, only if all those features are available (at least filament sensor, flament change.... maybe blackout is not possible...)
    Thanks, Simon
    Opublikowany : 03/03/2018 1:49 pm
    thrawn86
    (@thrawn86)
    Hello,
    Thanks,
    Simon
    Hello,
    Thanks, Simon
    I'm sure they're working on the power panic, but I'd imagine you would HAVE to use the accessory port OR have the pi on backup power somehow.
    The filament sensor does work just fine from a Pi, however.
    Opublikowany : 04/03/2018 12:54 am
    Simon
    (@simon-16)
    Thank you for the answer.
    Does it work only with Pi Zero on the board or should it work with a Octoprint attached via USB? In the last case on my tests it dosn't work.
    Simon
    Opublikowany : 05/03/2018 9:19 am
    thrawn86
    (@thrawn86)
    Simon
    pi3 usb here, works fine. with super glossy or translucent filaments however, all bets are off.
    Opublikowany : 05/03/2018 7:04 pm
    Simon
    (@simon-16)
    Ok, then I was wondering what advantages could I have using a PiZero mounted on the Board?
    Seems the same as if it's connected via USB. Only to decide whether to purchase it or maintain an external one. 🙂
    Simon
    Opublikowany : 06/03/2018 11:41 am
