Moving print head out of way to remove print bed
ted.b3
(@ted-b3)
Sorry if this has been answered anywhere but I can't seem to find an answer.
When my prints finish my head homes the X and Y axises (using Prusa Slic3r) but the Z axis stays at the height of the last printed layer. On low height prints it is a pain to remove spring steel sheet. I have to manually move Z axis up using the control panel.
Is there a way to ensure the Z axis moves to a height when it is easy to remove/replace the sheet? Say it moves to it's highest possible height when a print is done before the X and Y axis home?
Thanks in advance,
Ted
Respondido : 21/03/2018 7:35 pm
ACDawg
(@acdawg)
Re: Moving print head out of way to remove print bed
Just add a line in the end of print gcode, right before it moves X and Y. G1 Z200, or something like that
Respondido : 21/03/2018 8:28 pm
Sulya
(@sulya)
When on main screen you can hold the knob for a few seconds and it will let you move the Z axis, I find it easy enough
Respondido : 21/03/2018 9:00 pm
robert.b52
(@robert-b52)
Here you go.
https://shop.prusa3d.com/forum/original-prusa-i3-mk3-f30/custom-end-position--t14826.html
Respondido : 21/03/2018 9:05 pm
ted.b3
(@ted-b3)
Awesome....thanks!!!!!!
Respondido : 21/03/2018 10:01 pm
robert.b52
(@robert-b52)
No problem. I had that thread bookmarked as Neil's solution worked perfect for me.
Respondido : 21/03/2018 10:03 pm
Bytor
(@bytor)
Here's the GCODE I have in my OctoPi setup for after a print is finished
G90; Set to Absolute position
G0 Z205; move z axis up to 205
G28 X; home X axis
G1 Y150 F5000; move part out for inspection
M104 S0 ; turn off extruder heat
M140 S0 ; turn off heated bed
M106 S0 ; Turn off fan
M18; Move Freely
- 1st "printer" TIKO 3D
- 2nd PRUSA i3 MK2S with MMU v1
- 3rd PRUSA i3 MK2S
- 4th PRUSA i3 MK3 with MMU v2- 5th PRUSA i3 MK4 (upgraded from MK3) with MMU v3 (upgraded from…
Respondido : 21/03/2018 11:25 pm
Aravon
(@aravon)
In case you don't know the fast Z axis movement shortcut yet:
Press and hold the front panel knob for 2 sec then turn it to adjust the Z height.
Advantage : can adjust z height more flexibly.
Disadvantage: cost 2 more sec and need a finger.
Respondido : 22/03/2018 10:41 am
Kwaad2
(@kwaad2)
Are you holding out on any other shortcuts?
Hi, I'm Sean. I used to work on CNC machines.
I try to not make mistakes, but the decision is YOURS.
Please feel free to donate to my filament/maintance fund.
Respondido : 22/03/2018 11:09 am
