MK3 z wobble- is this the issue?
Sunnyday
(@sunnyday)
I've printed a PSU cover and I printed the part with 75% print speed, the final result came out like this :geek: (check the attached image) is this cause by the z wobble? How do I eliminate the Z wobble? I also wonder what print setting/Printer josef use for MK3 printed part that you shipped? I seem like I cant get the same print quality from my MK3 😳 😡
Opublikowany : 05/01/2018 4:53 am
Olef
 Olef
(@olef)
Re: MK3 z wobble- is this the issue?
I got a very similar result when printing a PSU cover from PETG, with the same sort of random diamond like shapes on the faces and a literal spiders nest of stringing. Took a long time to clean up and make usable. I was printing at 60% / .20, Slic3r PE, default PET temps. Something about large vertical flat faces the Mk3 does not like.
Opublikowany : 05/01/2018 9:00 am
Josef Průša
(@josef-prusa)
Member Admin
Change the infill pattern to grid, it is bleeding thru thr perimeters in this case 🙂
Founder and owner / Majitel a zakladatel
Opublikowany : 05/01/2018 9:20 am
Protoncek
(@protoncek)
Josef, would increasing number of perimeters from 2 to 3 help? I usually print with 3 perimeters; i think that i have more rigid walls that way (don't really know if it's true, though...)
Opublikowany : 05/01/2018 9:50 am
Olef
 Olef
(@olef)
I always use three perimeters but still had the issue. I will try changing the infill pattern, thank you Josef.
Opublikowany : 05/01/2018 11:23 am
