MK3 with Prusaprint File System Errors
Dirk
 Dirk
(@dirk-5)
I have problems to set up the MK3 with a Raspberry Zero W and Prusaprint (Octopi). I tried it connected directly to the MK3 Mainboard, I see the Pi boots up but I don`t get a connection via Wifi and the MK3 did not show up the IP address in the display (the option is set on on).
So got a mini HDMI adapter and viewed the boot up sequence on the pi zero.
There are a lot of errors showing up with the file system after the login prompt shows up. Ok maybe the SD card is corrupted. So I use a 2nd SD Card, same error spamming. 3rd Micro SD Card and, same problem. I don`t think that 2 brand new Micros SD Cards are corrupted. I tried to flash the SD Card from a different computer (maybe the writing or something else is a problem on the 1st PC) and I downloaded the Image for PrusPrint again, check the file etc, everything seems ok.
Long Story short, I always get that file system error spamming and I don`t get the pi running, solo or connected to the MK3.
I don´t found any similar post or error postings, so I hope somebody can enlight me and have the right idea.
greetings
Dirk
Napsal : 15/03/2018 8:42 am
Dirk
 Dirk
(@dirk-5)
Re: MK3 with Prusaprint File System Errors
I tested a brand new Raspberry pi 3 B with a new 8GB SD Card and the downloaded Version of Prust Print.
Same result, spamming error message with EXT4 file System errors.
it seems the Version that is online is corrupted or defekt.
Napsal : 15/03/2018 8:21 pm
Dirk
 Dirk
(@dirk-5)
I am not a normal Linux user, I have no clue to fix this.
2 diffrent Raspberry Pi´s 3 diffrent Micro SD cards, two diffrent PC to flash it, all the same result , error, error, error
Napsal : 15/03/2018 9:17 pm
hofinger
(@hofinger)
Same Problem here.
The Prussprint image does not work, Filesystem errors.
Now I flashed the normal octopi 0.14 Image and it works fine.
Napsal : 15/03/2018 10:39 pm
Dirk
 Dirk
(@dirk-5)
Did you had to change any settings in the original image from octopi except the Wifi settings?
Or is the standard octopi Image working with the MK3?
Napsal : 16/03/2018 8:37 am
RH_Dreambox
(@rh_dreambox)
I run PrusaPrint on Raspberry Pi3 (USB cable) without any issues. No special settings.
https://shop.prusa3d.com/forum/original-prusa-i3-mk3-f30/the-most-important-links-original-prusa-i3-mk3-t13545.html
Napsal : 16/03/2018 9:31 am
hofinger
(@hofinger)
You have to change some settings for the serial port to use a standard octopi image.
Somewhere in the Online-Manuals is described how, i think it was an article at help.prusa.com .
Couldnt find the link at the moment because i'm here via Smartphone.
Edit: found it: https://help.prusa3d.com/l/en/article/Loz15FAgEk-octo-print-raspberry-pi-zero-w
Napsal : 16/03/2018 11:45 am
