MK2.5 cold pull question
spark
(@spark)
Hi gang,
I'm in the process of designing front intake MK3 extruder body and wanted to know, how do you guys cold pull? I have a custom quick-release latch on my MK2S for this purpose but MK3, seems like the only way is G-code extruder reverse as eject won't work. Can you guys tell me if a quick release is useful for MK3 as I found with MK2 or has this not been an issue.
MK2S kit owner since 8/15/2017
Publié : 10/02/2018 9:22 pm
Chris
(@chris-16)
Re: MK2.5 cold pull question
i have loosened the tension on the bondtech and just given it a pull while heating up but only once because of the ptfe tubes and the filament sensor. don't want to damage either puling through a big blob
Publié : 11/02/2018 6:52 am
spark
(@spark)
OK, so basically it is donkey balls? I use my quick-release idler all the time on my MK2S and don't want to loose that functionality.
MK3 is crammed full of gubbins so it might not be possible but if cold-pull is annoying on MK3, I'll have to design a quick release for Bondtech system as well. Darn.
Publié : 11/02/2018 7:35 am
