LeadScrew Maintenance
Impruve
(@impruve)
Hey guys...
My other printer still uses the "good old" threaded rods for the Z-axis.... I often lubricate them with machine oil so i can get a smooth Z-axis movement.
Should the same be done with the LeadScrews for the MK3? Didnt see anything about that on the manual.
Thanks in advance.
Postato : 18/12/2017 1:44 pm
Re: LeadScrew Maintenance
the mk3 uses plastic/nylon leadscrew nuts which need minimal lubrication. i put a drop of oil on them when assembling my mk2 and nothing since been like that over a year
Postato : 18/12/2017 1:59 pm
keith.m10
(@keith-m10)
I expect it is POM(Delrin) which does not need much if any lubrication.
Postato : 18/12/2017 2:08 pm
Impruve
(@impruve)
Ok... thanks for the info.....
Postato : 18/12/2017 11:03 pm
surfgeorge
(@surfgeorge)
Just make sure to use lubricants specifically designed to work with metal/plastic pairings.
Plastics can swell and soften from contact with mineral and synthetic oils.
You can search for RC helicopter grease which is specifically designed for metal pinion - nylon/POM main gear pairings.
Postato : 19/12/2017 8:24 pm
Impruve
(@impruve)
Ok, thanks =) I will look into it!
Postato : 19/12/2017 9:28 pm
