LCD backlight dead?
Ignis Veneficus
(@ignis-veneficus)
LCD backlight dead?
Hi!
I used about one month long my new assembled MK3, and the backlight of the LCD begin change the brightness, and now it full turned off.
(The LCD still working, just the backlight is dead)
Any help welcome.
Csaba
Posted : 04/04/2018 9:11 am
Kai
 Kai
(@kai-2)
Re: LCD backlight dead?
I bet you already try´d to plug the ribbon cables out and back in.
If not, try that first.
When the printer is turned off !!!
If your Backlight is really not funktional, you should contact Prusa via chat.
I bet they can help you.
nec aspera terrent
Posted : 04/04/2018 11:45 am
RH_Dreambox
(@rh_dreambox)
On the back of the LCD display is a small potentiometer to adjust the contrast of the display.
Screw it slightly and see what's happening.
Posted : 04/04/2018 11:50 am
Ignis Veneficus
(@ignis-veneficus)
@kai.r3
I try both side, not helped 🙁
Thanx
Posted : 04/04/2018 1:31 pm
Kai
 Kai
(@kai-2)
Then you should just contact the support.
It´s absolutely easy when you use the chat window down on the right side of the prusa website.
Sometimes it takes a moment, but they helped me every time.
nec aspera terrent
Posted : 04/04/2018 5:04 pm
