Layer shifting on mk3 - Options
Rohotnee
(@rohotnee)
Hey guys, so I'm having some problems with layer shifting on my Prusa Mk3 and are looking for some advice before I strip down the build and retry. The lines are very pronounced which looks worse than prints on my old printrbot play, but the biggest issue is the layer shifting. Any advice?
What I've done:
[*] Updated the firmware
[*] Tightened belts (reasonable force, nothing crazy)
[*] Printed at 20% speed
[*] Turned off crash detection (Though no crashes detected in logs)
[*] All tests are done using defaults, saved to the sd card from slic3r (Prusa edition)
[*] Checked for rubbing/resistance/where I can
Any advice?
Publié : 02/04/2018 6:19 pm
reid.b
(@reid-b)
Re: Layer shifting on mk3 - Options
Which axis- looks like the Y axis only? Either way, double check that you have tightened all grub screws on all motors.
Publié : 02/04/2018 6:24 pm
Rohotnee
(@rohotnee)
Looks like this was it, it must have come loose at some point but my Y-axis is MUCH better now, thanks a bunch..!
Publié : 05/04/2018 5:01 am
