Just recieved my fully assembled MK3 and I'm having some troubling issues right off the bat
Artifact 3D
(@artifact-3d)
It looks like the test print included with the printer (the orange and black prusa logo) came out fine. But when I try to print things myself, even after calibration, everything comes out with lines far-spaced when trying the test files included on the SD card, as well as my own files created using Prusa Control with the proper material settings (so far I'm only using PLA).
I've been using Ultimaker machines heavily at a lab for the past few years and I decided to buy my own more affordable machine so I can work from home, and after looking at some reviews I chose the Prusa MK3, which arrived today.
On my first 2 attempts at printing, the PLA warped immediately and is peeling up off the of print bed (I'm in a very small, contained, room temp environment with no nearby air flow.) I've tried to re-do the calibration, but at certain points the display shows nonsense characters and I have no idea what to do from that point on. At first it says to remove the steel magnetic sheet, calibrates for around 10 minutes, then shows nonsense characters so I have to exit calibration. Perhaps my mistake was trying to perform calibration on a pre-assembled machine and it ruined things. I just wanted to re-calibrate in the case things had shifted as it had come all the way from Europe.
I'm hoping I can run a calibration like what appeared when I first started up my machine, as all of the calibration tests that appear in the menu show gibberish characters (not another language, just random ascii characters) instead of words at some point during calibration and I have no choice as to exit as I don't know if it wants me to put the steel spring sheet on, do something with filament, etc.
https://imgur.com/a/Xa3Qa < this is a link to an imgur album showing my print of the prusa logo included on the SD card, as well as the one that was stuck to the print bed on my machine when I received it. Mine is the silver one with the heavily messed up bottom layer, the orange and black one is the one sent from the factory. The same messy bottom layer issues occurred when I tried printing my own simple box models exported from Prusa Control and had to be canceled before they wasted more filament. The last image of the album shows what the calibration display says after it says "please remove steel sheet from print bed". It's just nonsense and I have no idea where to go from here.
Hopefully this an easily fixable settings issue rather than something that will require extensive modification, as the logo included in my box shows my machine is capable of clean prints. I am extremely grateful for any advice.
EDIT: Here's what the first 2 layers of plain flat box prints look like after firmware update and calibration:
Cable connections have been double checked
Opublikowany : 13/03/2018 6:42 am
Nikolai
(@nikolai)
Re: Just recieved my fully assembled MK3 and I'm having some troubling issues right off the bat
Check the cables from the display to the board. They might got loose during shipping.
After you fixed that, proceed with the regular calibration steps by the guide.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Opublikowany : 13/03/2018 7:15 am
Olef
 Olef
(@olef)
Looks like your nozzle is too far from the bed. Clean the spring steel plate with 99% isopropyl and carry out a first layer calibration to adjust your live Z. See the 3D Printing Handbook 6.3.1 Calibration flow and wizard.
Opublikowany : 13/03/2018 7:52 am
Artifact 3D
(@artifact-3d)
Thank you, although I'm still concerned about the random ascii characters and distorted pixel objects appearing during calibration, doing first layer calibration instead of the calibration wizard seems to have greatly reduced my spacing/warping issues.
Opublikowany : 13/03/2018 8:14 am
RH_Dreambox
(@rh_dreambox)
If you get random ascii characters on the display even after checking the cables, I think you should flash a new firmware. There may be a problem with the software. Make sure you are using the latest firmware (now 3.1.3 March 8, 2018).
Clean the bed carefully and make a new first layer calibration (lower the nozzle).
Opublikowany : 13/03/2018 8:42 am
Peter L
(@peter-l)
Keep in mind that the initial calibration and Z adjustment steps are not optional. If you can't get through those steps for whatever reason (i.e. bad display), you won't get acceptable print quality.
I agree that it sounds like there may be a loose connector to your display. It's also possible you have a bad display or motherboard.
Opublikowany : 13/03/2018 5:05 pm
Artifact 3D
(@artifact-3d)
It looks like it was probably a problem with the firmware shipped from the factory. I updated the firmware last night to the march 8th release and I'm currently running the calibration wizard and I've gotten to steps I was unable to get to before because the screen glitched out previously at these steps.
Opublikowany : 13/03/2018 10:17 pm
