If Prusa sells remote control module, will you buy?
Seite 2 / 3
Area51
(@area51)
Mitglied
Re: If Prusa sells remote control module, will you buy?
I am a bit concerned because of all the informations around problems with octoprint.
That is why i decided to get a toshiba FlashAir SD Card.
It arrived today and works just perfekt.
Even sending new Profiles to my rc transmitter works.
Now i´m looking forward to get my MK3. 😀
I am very interested in Toshiba FlashAir SD card too, but not sure if it works or not.
Please do let us know your experience when you get your MK3.
It works great! 😀
I have been using Toshiba FlashAir W-03 for over a year now, first on my MK2/S (and K8200) and now on MK3.
When setup correctly you can drag, drop, read, move, copy and delete files on the SD card without removing it, directly as a normal file share.
The card takes only little power from the LCD to work. It is transparent to the firmware on the printer and you can use it while printing to prepare the next print. This is one of the best add-ons I have... 😉
Veröffentlicht : 17/01/2018 2:59 am
Tomaz
(@tomaz)
It works great! 😀
how exactly does it work. do you need to connect to it like to wireless network? or it connects to wifi and is then reachable from computer? i sounds great, but i would not like to switch between wifi and sd card on my computer
Veröffentlicht : 17/01/2018 1:00 pm
Area51
(@area51)
Mitglied
It works great! 😀
You can picture the card as a normal SD card with a build in network computer. The firmware (printer) only sees it as a standard SD card, but the network computer can read and write files received from the network.
The WiFi SD card has two working modes - as client on existing WiFi network or as standalone (hot spot).
I use client mode on existing WiFi network. In that mode, all devices on the network can access the files on the card, like a file server/share.
In standalone mode the card creates a new network you can connect your computer to for file access. As most computers only connects to one WiFi, you will loose access to your normal WiFi - the WiFi server in the card can route traffic to existing WiFi, but I think this is a complicated and slow setup and have never tried it.
To configure the card you can either write directly to a CONFIG file on the card or use a free program from Toshiba.
When first setup, you only have to change setup if you change password on your WiFi 😉
Veröffentlicht : 17/01/2018 3:37 pm
Tomaz
(@tomaz)
didn't know for client mode. will deferentially buy it now 😀 thank you for great explanation
Veröffentlicht : 17/01/2018 3:47 pm
imod.systems
(@imod-systems)
Try a Toshiba 16Gb wifi W-03 SD card. I ordered one to try.
https://www.amazon.com/Toshiba-Flash-Wireless-Memory-PFW016U-1CCW/dp/B00UOYPZNE/ref=sr_1_1?ie=UTF8&qid=1516020587&sr=8-1&keywords=flashair+16gb
Thanks for this!
Veröffentlicht : 17/01/2018 6:29 pm
Sverker
(@sverker)
Does Any one know
IF a 32 GB Toshiba wi-fi Will work with mk3. I dont know if i would Ever need such a large one but IF i am bying why not
Veröffentlicht : 17/01/2018 7:48 pm
Kai
 Kai
(@kai-2)
I´ve got one here.
The W-04 Toshiba FlashAir 32GB.
It works just perfekt.
Even in my RC Transmitter.
The only Challange is the configuration, that you can use the Card in your network with the ability to connect a network share.
The other way is to use the upload cgi (already configured by default) on the Cards internal "webservices".
Give me a second and i will post my config.
nec aspera terrent
Veröffentlicht : 17/01/2018 10:49 pm
Sverker
(@sverker)
Thanks i Will order 32gb w3 now
Veröffentlicht : 17/01/2018 10:51 pm
Kai
 Kai
(@kai-2)
[Vendor]
CIPATH=/DCIM/100__TSB/FA000001.JPG
APPMODE=5
VERSION=Your-Version
CID=YOUR-CID
PRODUCT=FlashAir
VENDOR=TOSHIBA
LOCK=1
WEBDAV=2
APPNAME=PrusaI3MK3
APPSSID=YOUR-SSID
APPNETWORKKEY=YOUR-KEY
BRGSSID=flashair
BRGNETWORKKEY=YOUR-KEY
UPLOAD=1
UPDIR=\upload
[WLANSD]
DHCP_Enabled=NO
IP_Address=192.168.0.xxx
Subnet_Mask=255.255.255.0
Default_Gateway=192.168.0.xxx
Preferred_DNS_Server=192.168.0.xxx
nec aspera terrent
Veröffentlicht : 17/01/2018 10:56 pm
Kai
 Kai
(@kai-2)
You will have to edit the italic parts.
You have to create a folder "upload" directly on the SD-Card (root).
With this config you have an Access Point AND a "normal" network client running the same time.
Some Values will already be on your Card, like the CID etc.
You can keep those values as they are.
Btw. the Card needs about 20 seconds to boot after power on.
nec aspera terrent
Veröffentlicht : 17/01/2018 10:59 pm
Kai
 Kai
(@kai-2)
You will find a lot more Information on this Website: https://flashair-developers.com/en/documents/api/config/
But be carefull and always keep a backup before you change the config.
nec aspera terrent
Veröffentlicht : 17/01/2018 11:05 pm
Dewey79
(@dewey79)
Does anyone else make a good one other than toshiba?
Veröffentlicht : 18/01/2018 1:20 am
Area51
(@area51)
Mitglied
Take a copy of the CONFIG file before edit. The values VERSION= and CID= is unique to the card!
If you set the value of UPDIR=/ the entire card will be visible.
Finding an unused IP on the WiFi can be tricky for non-network users, so set the DHCP_Enabled=YES. The assigned IP number can be found in the Support menu on MK3 under FlashAir.
If DHCP_Enabled=YES there is no need to specify IP_Address=, Subnet_Mask=, Default_Gateway=, Preferred_DNS_Server= and Alternate_DNS_Server=
Veröffentlicht : 18/01/2018 5:08 am
Tinkerwest
(@tinkerwest)
This looks very interesting but I'm gonna need a little bit more help in the form of a cookbook. Found this on YouTube.
Do you guys think this will help or is there a better recommendation.
Also any pros and cons on the Toshiba FlashAir W-03 vs W-04 and 16Gb vs 32Gb
Veröffentlicht : 19/01/2018 12:27 am
josh.w3
(@josh-w3)
Mine is still on order, so I can't speak from experience, but I went with the 16GB W-04 based on the following logic: 1) Toshiba says the W-04 has an updated wifi chipset for 'increased performance'. Couldn't find any details on that, but newer wifi gear is generally better than older wifi gear. 2) Based on the average size of the models I print (10-30MB), a 16GB card will easily hold several hundred prints (~16000/30=533). Why would I need anything larger when I can just delete the last hundred models from the card to make more room? Plus, it seems like the EINSY has to re-scan and catalog the whole file structure of a newly inserted SD card before it can show you a menu of files...which explains why it seems to be getting slower at doing so as my card gets more full. I don't know if that will matter with the wifi card since technically it won't be physically removed or inserted anymore, but I intend to keep my card 'clean' with far fewer than a hundred print jobs.
The only justification I could come up with for a 32GB card is if I eventually planned to use it with a digital camera instead of my printer, but decided the chances of that are slim (who wants to transfer 20GB of photos/videos over a less-than-stellar wifi connection?). So I spent the money getting a smaller W-04 instead of a larger W-03.
- My MK3 Power Supply and Pwr Mgmt Upgrade
Veröffentlicht : 19/01/2018 1:11 am
Tinkerwest
(@tinkerwest)
Thank you, just put a 16Gb W-04 on order. Now all I need is a little more detailed cookbook for how to.
Veröffentlicht : 19/01/2018 1:43 am
Olef
 Olef
(@olef)
Good info in this thread. I now have a 32GB Flashair installed in Mk3 and mapped as a network drive on my PC. I plan to store gcode on the SD but print it via Octopi which is on a RPi3, not a zerow.
Veröffentlicht : 19/01/2018 2:09 am
Chris
(@chris-16)
I just spent a couple of hours on this so let me save you some time.
Here you will need to download the flashair config software
http://www.toshiba-memory.com/cms/en/products/wireless-sd-cards/FlashAir/flashair-wireless-sd-card-W04.html
here is the dev page in case you don't end up solved by this post - you can look up what the settings names mean and what the expected are
so, here we go.
I got my 16 gb w-04 card today. after spending a few hours confused, took a break and watched " I Tonya" and felt better about myself and my life, so returned to configuring.
I setup the card using the utility. start by taking a picture of the text on the back of the card and then inserting the card in your compuer and then starting the flashair config software you have already downloaded and installed
First select Network settings and type in your routers name and password like you are connecting a computer. then hit apply and click the arrow in the top left
next, go to the initialize card menu item and type in the mastercode from the picture you took of the back of the card and type the code in if it does not appear here.
from there, go to your router and view connected devices. Make sure you see the card, if you do. exit the utility
at this point we need to do some editing of the cards config.
I know nothing about mac's so if someone with a mac could chime in here i would love it but here are the windows instructions
Open the card from my computer, under tools (win7 i assume same on win10) select folder options. select the view tab and make sure you can seen hidden files and open the /SD_WLAN/ folder
in the /SD_WLAN/ folder open the config file and make the following changes
add these lines (required)
UPLOAD=1
UPDIR=/
WEBDAV=2
upload 1 make the card read and write able
updir sets what directory you can write to. I gave mine root
webdav 2 means you can map it via webdav
edit to match (required)
APPMODE=5
This turns the wifi to a client on your network rather than a standalone ap
optional but make my life easier
DHCP_Enabled=NO
IP_Address=192.168.1.103
Default_Gateway=192.168.1.1
Preferred_DNS_Server=192.168.1.1
NOISE_CANCEL=2
DNSMODE=1
This sets the card to a fixed address which is much easier for mapping to since it will always be this address you can choose another address or try the
appname=nameyouwanttocallthecard
I prefer specifying the address myself.
One of the main problems I had was that the mastercode which is the mac address for the card, was not set. once i set that and appmode=5 it was on my network and working like a charm. transfer is fast with the w04 card.
In case you need help mapping the card open windows explorer and go to network, right click and choose "map network drive"
Then type in either the ip address or the appname you chose, select a drive letter and click finish. if it is not detected try clicking browse and see if it displays.
Veröffentlicht : 19/01/2018 7:42 am
Chris
(@chris-16)
one last thing, in the printer menus you need to go to settings and cd card and click on that line to change it to flshair so it gets the extra juice it needs to run the wifi chip.
Veröffentlicht : 19/01/2018 7:54 am
Sverker
(@sverker)
Great instructions
Thanks
Veröffentlicht : 19/01/2018 9:03 am
Seite 2 / 3
