Hotend heating/cooling jumps
Hello guys,
I have a mysterious failure since a week. If I heat up my hotend everythings fine until it reaches ~170-180°C then the temperature drops immediatly by ~50°C and the hotend continue with heating. If it then got to 190°C it seems to be way too hot because there comes smoke out of the nozzle.
I tested this with original prusa PLA and also other PLA.
If you then cooldown the Hotend the same happens again. So it cools down to ~120°C and then suddenly shows up ~180°C.
To detect the exact temperature where this error occurs i tried to heat up slowly.
Any suggestions? Maybe a broken Thermistor?
Thanks in advance.
Re: Hotend heating/cooling jumps
More than likely a broken or intermittent wire for the thermistor. Check all your bundles for kinks, check the thermistor connection at the Einsy.
So Double checked the cable ans the Connection to the Rambo board. Seems all fine to me. Only thing I saw was that the cable coming out from thermistor seems a little to hot because it changed color from white to brown.
Everything else seems to be fine.
I also tried to shake the cable and watched for temperature changings but nothing happened.
So I ended up with changing Thermistor to a PT100 from E3D and therefore rebuild the firmware with proper changes. I also changed the wiring. But the problem persists. The Temperature of the hotend's still jumping by an offset of about 50 Degrees. I don't know what to do.
Please help!!!
Please help!!!
What firmware changes did you do?
I am also planning to change the standard thermistor to PT100 and amplifyier board and a new 40W heater cartridge. The only change I reckon is needed to uncomment this line:
#define E3D_PT100_EXTRUDER_WITH_AMP
On all the other places I see checks whether this is defined or not, so it will do all the other changes automatically.
Michael
Hi there,
I'm looking for advice on how to connect the 3-wire PT100 to the Einsy
Looking at the documentation:
https://github.com/ultimachine/Einsy-Rambo/blob/1.1a/board/Project%20Outputs/Schematic%20Prints_Einsy%20Rambo_1.1a.PDF
Page 5 has the EXT P3 layout. I'm going to connect GND to [7] and 5V to [1].
My question, the signal wire needs an analog input, do I connect to the non-GND pin for the current extruder thermistor input or choose another?
Please help!!!
Hi stevenSTS,
Please help!!!
Hi stevenSTS,
My initial thought worked, printing running well now.
